hi guys, im new here!
I still dont really understand watts, amps, or voltage, but I wanted to start a small project for my fishtank.
I want the light to turn on for eight hours a day, and turn off for sixteen hours. Simple right?
The cable for the light had a switch in it, but I removed the plastic case and switch, exposing the wire (see picture). I’ll share the cable specs at the bottom.
I want to use an Arduino Nano to program the timer, and I am thinking about eventually adding a 1-digit 7-segment display to show how many hours remain until the light switches on or off.
I can handle the programming, but does anyone have any suggestions for the wiring part? Will I need relays.. or resistors? How should I go about making the “schematic”? How do I keep all the amps and volts and whatever compatible?
I am open to reading/watching any resources you can recommend. I have background in coding and I played with Arduino as a kid, but I didn’t do much past the blink experiment. I would love to learn more about electronics because there is so much to do!
Please let me know if I can answer any questions. Thank you so much for any help, I appreciate it!
Specifications:
Elegoo Nano Unsoldered OR Lavfin Nano Soldered (both are Arduino Nano equivalent)
5611AH 1-digit 7-segment display
Power Cable (see pictures)
